PerfectWave PowerPlant 12 Regenerator
Front Panel
Rear Panel
Our most powerful compact AC regenerator, the P12 regenerates new, safe, and pure AC from your home's power outlets for breathtaking improvement.
The PerfectWave PowerPlant 12 features an ultra-low impedance analog power amplifier, pure DSD FPGA based sine wave generator, and the lowest distortion available in a PowerPlant. Providing 1250 watts of pure power, the P12 is capable of powering medium to large power amplifiers, as well as the smallest pieces of source equipment.
Clear
Talk to a Hi-Fi Specialist
1-800-psaudio
Design
The P12 takes your incoming AC power, converts it to DC, and then regenerates it, producing new sine-wave-perfect, regulated high current AC power. The input voltage to the P12 is fully protected by state-of-the-art clamping devices and the output is fully regulated, so even large voltage swings that would normally damage connected equipment are made safe by either clamping or regulating. The P12 PowerPlant features 8 outlets (US version) across 4 separate zones and delivers 1250 watts of pure, regenerated power to each receptacle through thick, copper busbars.
Application
In the process of regeneration, any problems on your power line, such as low voltage, distorted waveforms, and sagging power, are eliminated. With your system powered directly from the output of the P12, you can expect far better micro and macro dynamics, as well as cleaner, lower background noise. This is one of the most important pieces of audio equipment you can own, building a firm and reliable foundation for your system that will serve you for years to come.
Technology
Overview
MultiWave
CleanWave
PowerPlants are personal AC generators that provide hard-working, perfected results from the AC power line. Power regeneration uses active components, like those found in large, powerful audio amplifiers, to rebuild the AC power and produce clean, clear, distortion-free, regulated AC to the equipment. The results of feeding your equipment with low output impedence are dramatic: unrestrained dynamics even under the loudest passages, an open, wide soundstage that does not collapse with volume and a naturalness to the music that is remarkable. The 4.3-inch, full color display on the front panel of the P12 allows you to measure distortion, both incoming and outgoing, improvement levels, and power consumption. You can also adjust your settings, such as the turn on/off sequence and the output voltage, as well as turn individual zones on or off, and measure the power quality with either the built-in oscilloscope or the THD analyzer.
One of the major advantages of generating new power from old is the ability to also generate new waveforms that enhance the capabilities of the power feeding your equipment. MultiWave extends the peak charging time of the sine wave so connected equipment has more energy storage and less power supply ripple. Turning MultiWave on is like adding a larger capacitor bank to your conected equipment's power supply. The audible results are dramatic and produce a bigger soundstage that sounds far more natural than with a simple sine wave.
CleanWave is another feature of the Stellar P3 PowerPlant and helps connected equipment demagnetize their transformers. AC power is never quite symmetrical and the small asymmetry that occurs can magnetize connected power transformers. Activating CleanWave from the P3 remote control can remove this problem from connected transformers resulting in far cleaner audio.
Specifications
Overview
Signals
THD & IM
Output Power
Unit Weight 13 lbs (5.9 kg)
Unit Dimensions 17”x3”x12” (chassis only; 13” deep with connectors)
Shipping Weight 16.5 lbs (7.5 kg)
Shipping Dimensions 22”x8”x17
Color Options Silver, Black
Voltage Options (Factory Set Only) Japan 100V, North America 120V, Europe/Asia/Australia/New Zealand 230V
Main Power Inputs IEC C14
Accessories Included US (NEMA 5-1 5P, all versions), Schuko (CEE7/7, 230V versions), UK (BS 1363, 230V version)
Audio Inputs RCA (unbalanced), XLR (balanced)
Speaker Outputs S300 Copper base nickel-plated binding posts (2 pair per channel)
Speaker Outputs M700 Copper base nickel-plated binding posts (2 pair)
Other DC trigger input, 3.5mm 5-15VDC
Warranty 3 years parts and labor
Reviews
INDUSTRY
USER
AWARDS
Product Enquiry
Each product contains this form in order to allow potential customers to ask the Sales team questions about it directly.
Stop by for a tour:
4865 Sterling Dr.
Boulder, CO 80501
