The balancing act
August 24, 2019
 by Paul McGowan
There's been an ongoing debate between balanced and unbalanced cables in HiFi as long as I have been involved. And, that's a long time.
I remember spirited debates with Audio Research founder Bill Johnson about it. AR equipment was a long hold out in adding balanced to their products but over time they gave in, and I believe it to be a good thing.
Balanced interconnects sound better than single-ended do. I know, that's perhaps too strong of an opinion, but I have yet to have any prove me wrong.
There's little dispute of the technical advantages when balanced is done right: noise and distortion rejection, 6dB more signal, separation of signal conductors from shield duties.
What many folks perhaps don't think about when mentally dissecting a single-ended cable is that there are only two conductors inside, and one of them is the outer shield. This asymmetry of design, where the hot lead is a solid core, stranded, or other construction, and the return lead is made of aluminum foil or braided/tinned copper, is not ideal. Rather, you'd want both conductors in a properly designed cable to be identical while the outer shield is separate and distinct from the conductors. That construction is only available in a balanced cable.
My question is a simple one. Why do we manufacturers bother keeping the single-ended RCA connectors on our equipment at all?
The answer in PS Audio's case is likely the same as others. Compatability.
But it's a shame.
Subscribe to Paul's Posts
Post Author's Image
Paul McGowan
Never Miss A Post
Lorem Ipsum
Lorem ipsum dolor sit amet, consectetur adipiscing elit. Nullam orci felis, eleifend sit amet blandit sit amet, convallis ut turpis. Vestibulum tortor ex, pharetra convallis eros a, facilisis elementum dolor. Ut sagittis malesuada odio, sit amet ultrices mauris tristique a.
Stop by for a tour:
4865 Sterling Dr.
Boulder, CO 80501
